RE: 3w break in
You shouldn't have any problems flying the plane during the break-in. Don't over load the engine with too big a prop, run 32:1 petroleum oil, make sure the carb is set slightly rich, keep the engine cool with adequate air intake and exit in the cowl, work the throttle and avoid hovering, make sure your fuel lines can't suck an air bubble, and use a fuel filter.
