Is my Freedom Flyer toast?
Well, I think my FF is screwed. It had a bad crash this morning and I needed to remove the electrics cause the plastic part that holds them in place was broken. Now the servos (still outside of the plane) won't react correctly to the transmitter. I don't know what could have happened, they were working after the crash, but not once I took them out and connected them outside the plane. I check all the solder points visually, I had to resolder two wires, but it still doesn't want to respond correctly. The servo's will move slightly, but very slowly and it interferes with the motor, cuts on and off, when I'm trying to actuate the servo's. Any Ideas? This is really dissapointing.
