RCU Forums - View Single Post - Nose In Hover
Old 01-17-2004 | 05:37 PM
andy36
Default RE: Nose In Hover
ok i'll reveal my secret of nose in hovering for unlimited(well almost)time
all you have to do is pretend that the heli is a large circular wing!!now to continue ,swing the heli from tail in 180 degrees at a good height(at least 25foot) and well away from you..ok so far?right now your quaking,all you gotta do is...."LIFT THE WING THAT IS LOW"this will keep the heli in the same position,this knowledge comes from flying fixed wing and when landing,nose in you gotta,yep you guessed,lift the wing that is low,this means if the heli is starting to tilt to the left,put your cyclic stick to the left,if heli(still pointing towards you)tilts towards you pull the cyclic stick towards you slightly,this is now making heli hover nose in,believe me i've done it for more than 20 seconds and ive only been flying power heli since last april.i must admit i practised this for many hours on sim before i tried it.I still nearly sh1t myself when i try it.heaven help me when i try loops etc...lol[>:]
