RCU Forums - View Single Post - Mechanical advance ignition
Old 01-18-2004 | 12:31 AM
shenion
Default RE: Mechanical advance ignition
Not a real problem on most engines.
Many run with fixed timing at near full advance all the time. I know several that just removed the advance and set it to the max setting; just so they don't have to mess with the linkage.
The retarted timing reduces the idle torque vibration. I have seen mechanical advance work better than electronic because it advances earlier then revs up faster.
