RCU Forums - View Single Post - GP CHRISTEN EAGLE
Old 01-18-2004 | 07:36 AM
  #170
hilleyja
Default RE: GP CHRISTEN EAGLE
ORIGINAL: rfw1953
Jim, correction on the above post about using a True Turn adapter. This was incorrect. Sorry about that. I had the prop bolt tapped and threaded so the above mentioned spinner bolt could thread right into the prop bolt. No adapter needed. Keep in mind, this was on the Pitts so on the CE the lengths may be a bit different. Please excuse my error on this. I thought about it after I went to bed last night and was think about this and realized I had made this mistake. Again, this solution really did work well in solving the spinner bracket issue with the stock spinner.
I looked into the Tru Turn adapter for the Fuji and that is exactly what it is, a replacement bolt that has been tapped and threaded at the head. I'm hoping the GP spinner will work because a 4" Tru Turn spinner is EXPENSIVE.
