RCU Forums - View Single Post - Sig 1/6th J3 Cub
Old 01-18-2004 | 12:27 PM
tubig
Default RE: Sig 1/6th J3 Cub
i've managed to work some on the fuse. it takes a while to build this as, you can see, it's stick built. the most frustrating part is keeping the spruce stringers that form the cabin outline from breaking off. they are just end joined to the balsa sides and that doesn't provide a good glue joint. still, it has been an enjoyable build so far.
ID:	91764   Click image for larger version
