RE: whats a starter box
most race oriented engines, in hopes of reducing weight and increasign horsepower, do not use a pullstart or roto start mechanism. These engines will require an outside source to help them get started. a starterbox is a box with a motor attaced to a rubber doughnut that helps jumpstart then engine by turning over the flywheel. A starter box is normally not able to be used on most monster trucks, with the exception of some 'truggy' type.
