RE: hall sensor
Hey Joe I plan on ordering TIM 6 kit & PE coil from JEH tomorrow.Will this trigger properly with points as I don't mind using them to simplify everything.I have a Q35 W/points and am trying to shed weight.Also what do you use to cut down your flywheels as I want to use it just as a hub to strengthen area between threads and hub in case of crash.Thanks[&:]
