RCU Forums - View Single Post - Elevator and Stabilizer
Old 05-26-2002 | 11:00 PM
Ptarmigan's Avatar
Ptarmigan
Default Elevator and Stabilizer
Originally posted by Crosswind
When you say "keeps going downward" do you mean you have to add down trim in the elevator for level flight? If that's the case your stab or wing incidence is off. If it's a high wing plane shim the trailing edge of the wing up a tad to give it less positive incidence. I assume the stab is glued in and would be hard to adjust at this point. If it's a low wing plane you might have to modify the wing saddle a bit to raise the trailing edge. If that's not what you're referring to, please clarify your question with a bit more detail.
I am right now assembling my Sig Kadet LT-40 ARF. The elevator points downwards whenever I turn both sides of the elevator and stabilizer.
