RCU Forums - View Single Post - Elevator and Stabilizer
Old 05-26-2002 | 11:54 PM
Mike2002
Default Elevator and Stabilizer
I really don't see the elevator drooping a problem if the control rods are not hooked up yet. When they are hooked up, the control rod should keep it level. But if it is not level when the rods are hooked up, then you can change that by usign your radio trim tabs or you can take the screw out of the servo and rotate it one spot.
