RCU Forums - View Single Post - The TRUE cure time of epoxy...
Old 01-19-2004 | 10:47 PM
Phi3l
Default RE: The TRUE cure time of epoxy...
Don't forget temperature.
If you work in a cool basement or garage epoxy takes a bit longer, too.
If the temp in the shop is cool AND you happen to get a bit less hardener than resin, it can take even more time.
Phil in MN
[8D]
