RE: Taurus engine
"MINE DID NOT SPARK"
I thought the engine ran, but ran poorly???
Hopefully you've solved the problem. Perhaps you have a bad wire connection. Or I once saw a sensor that was damaged by the timing ring due to air gap being to tight. If you looked closely you could see a wear pattern on the sensor.
