RCU Forums - View Single Post - Should I use Resin & Hardner or Epoxy?
Old 01-20-2004 | 12:41 AM
phread59
Default RE: Should I use Resin & Hardner or Epoxy?
For any construction or repairs you want epoxy. Resin is not a glue. 1 set of 4 oz epoxie tubes goes a long way. You just have to put enough to coat 2 parts together. If you get epoxie oozing out of a joint you used too much. Learning how much to use is a learned thing. Use it some and you will get the hang of it. Good luck.
Mark Shuman
