RCU Forums - View Single Post - antenna length
Old 01-20-2004 | 07:36 AM
gus
Default RE: antenna length
I believe all receivers in the 72MHZ band have a 1 meter antennae length...
checking with Hitec ... (Look on their "other accessories" page at http://www.hitecrcd.com/
part number 54001 Green Green Antenna Wire With Bobbin for Feather Receiver
part number 58011 Black Antenna Wire for Aircraft Receivers Except Feather Receiver
So, I guess the feather receiver has something different.
aaahhh... have a look at : http://www.hitecrcd.com/Receivers/featherrx.htm then click on the FAQ.
Antenna length is 42 inches, or 1050mm.
Now, that is all pretty wierd because I convert 42 inches into 1067mm..... anyways, that is a half-inch difference.
gus
