RCU Forums - View Single Post - Engine tuning problems
Old 01-20-2004 | 03:03 PM
Montague
Default RE: Engine tuning problems
Gus is right on, you are just too lean. At mid-throttle, the lowspeed screw is playing a part, and it's not set as lean as the needle, so the problem goes away. That bit of info has me totally convinced that it's just the needle setting. Carb problems and such tend to be worse at lower RPMS, not better.
