RE: 10x hely programming to plane
Hi
i check main page and notice that trim value change when i switch from N to 1 so this is difference that i've noted.First i only check servo monitor and because stunt trim are inh on pos 1 and 2 trim button doesn't work.Then i start with a fresh memory and reprogramming plane only in N pos because i've to reprogramm trim values in every flight mode.Seams that sistem don't transfer trim value between flight mode but i thinks this is a limit of hely programm applied to plane.
Thanks again danny for your fast reply
Regards Mirco Barbieri
