Fuel tank w/engine rotated
The plane I'm building has the engine mounted at 90 degrees. Do I also rotate the fuel tank 90 degrees or does it matter? The construction manual just say's to install the tank parallel with the thrust line and in alignment with the carburator. I don't quite understand this fully.
Pete Killingsworth
Peshtigo, Wisconsin
