RCU Forums - View Single Post - Engine tuning problems
Old 01-20-2004 | 11:19 PM
CafeenMan
Default RE: Engine tuning problems
ORIGINAL: combatpigg
The high speed needle should be set with the nose pointed straight up.
Yes!
Turn it out = richer. Turn it in = leaner. You need to turn it out while somebody else holds the plane up. Keep the prop above you head and put the engine at full throttle to adjust the high-speed needle. It's easy. Just turn it and you'll see what happens.
