RCU Forums - View Single Post - 25oz RTF mini 3D.
Old 01-21-2004 | 12:41 AM
c/f
Default RE: 25oz RTF mini 3D.
Thanx Chuck,
You would'nt know Rick Fraley or Andy P? fellow combater friends of mine.
Another tip you can see in pix is a very small plastic Kraft Hayes clevis and pushrod, these clevises have a metal pin that snaps in so hard you need tools to remove, I have to super glue the robart ball in the horn then sand so that it is same thickness as horn body to get pin to latch. The Kraft Hayes music wire is also exceptionally ridgid as compared to dubro or sullivan IMHO.
Once again I do not want to afford the gram weights of any type of keeper or retaining nuts.
These clevises are also combat proven to the point that HS85MG servos have stripped the remaining plastic gear and clevis still holds many times over.
