Yep, all laser cut with formed leading and trailing edges. A bit of improvement on the building design thanks to many here on RCU for suggestions. Examples are duel servos on wing to eliminate the sloppy bellcranks, plans show standard hardwood beams as a well as bolt in motor mount for engines up to 60 size. Laminated spruce main spar for those concerned on wing strength. I will be finalizing the plans in the next 2 weeks to get laser cutting and components ordered. Any other improvements will be considered until then. This models is a very close match to the original. I have an original Sr Falcon built and all parts are interchangeable with each other. If you get a chance come out to the BARKS swap meet this weekend and look up our booth.
Bob Harris
Early RC Models
www.earlyrcmodels.com
