Here is the Dubro 4-stroke throttle linkage:
It works pretty good. I tried the 180 degree bend trick, but the push rod had too much flex in it. Plus, the throttle arm didn't move smoothly because the distance between the hole on the arm and the pushrod changed as the arm moved from half throttle to full throttle or half throttle to idle.
