Chea-Pass
I converted a House of Balsa,Chea-Pass intended for a .01 gas engine.My electric version has a AXI 2808/16...8x5 electric prop...8-1100cp battery.The plane is all laser cut with interlocking parts,this makes for a very fast build.I used four hitec hs-55 servoes(REand2servos in the wing).The AUW=28oz.The wood supplied in the kit was very light but a bit fragle.I had to replace the rudder with a stronger piece of balsa.The landing gear platform ( another weak spot)needed some extra plywood in this area.I actually fly my Chea-Pass without a landing gear.The plane flies great,it will loop,roll,fly inverted and do outside loops with ease.I plan on getting another Chea-Pass and make some major modifications in the future.
