RE: DuBro Safety lock clevices?
When using a Nylon pushrod with these clevices, what is generally used on the other end of the pushrod? A regular steel clevice? The reason I ask is because I thought these Safety lock types weren't really meant for adjustments, since once you put them on, they should stay on, and aren't really meant for adjusting the length of the rod. Is this true?
Patriot
