RCU Forums - View Single Post - ARF improvements (out of the box)
Old 01-23-2004 | 12:49 AM
Born to Fly's Avatar
Born to Fly
Default ARF improvements (out of the box)
What are the things that you will usually replace in a ARF kit ?
For me, I would strengthen the joints of Epoxy and CA. Note: CA are expensive and probably factory will try to skimp on that.
I would also replaces the Clevises and pushrods (if they are bent).
Replace the fuel tank with Du-Bro. Check for air leak.
Seal any exposed balsa with clear covering.
Make the planes lighter and drilling holes through low-stress frames.
Sometimes, replace the motor mount with Dave Brown mounts and even re-construct the firewall if necessary.
