RE: Name that plane!!!
that is clearly several planes that have been used to make one. The verticle fin is the giveaway. The top of the fin is not in line with the rest of the plane. The nose is from a tower trainer or similar. The wing looks to be from a trainer also and was made into a low wing plane. Im not sure about the rear part of the fuselage. The modifications should be obvious from the inside of the plane. Can you post a picture of the inside where the wing attaches?
