Another set of LT-40 warped ailerons
Hi DzlStunter,
Thanks for highlighting that thread; I'd actually read it yesterday! The difference in my warp is that if you placed the aileron in its neutral flight position and looked down at it from above, the warp would be in the X axis rather than the previous posts Z axis warp. I was not at all sure if I could actually correct the warp using the ammonia and water tricks. I guess if I were going to try that I'd have to soak the aileron with the solution and then pin it into the correct alignment on my work table?
Thanks for the helpful suggestions everyone,
Neil.
