10x origin mixing... at a total loss here
Hello, I have a 10X, and a R950S receiver.
I have two aileron servos, and two flap servos that have been direct Y connected. I used the quad flap wing for setting this up, plugging the ailerons in the appropriate slots, and plugging the one flap lead into the AUX-1 slot.
OK so far so good, everything moves in the right direction with the travels set (no DR yet). So now I plug the landing gear retract servo into AUX-3 (AUX-2 would've been the other flap servos if I didn't have them Y'd). I go into the prgm-mix 1 and mix Gear->AUX-3 with the gear switch inhibited (code 17). Set the mix to origin mixing.
And now I'm at a complete loss. I get nothing at either gear switch position regardless of offset or whatever. I know I messed something up, but what? This sucks! The manual is quite vague in this respect...
Thanks!
*misspelling
