RE: Another noob in need of help!!!
Are you holding in "up" elevator while they go straight up?
Once the plane is off the ground and has some air speed it should fly w/o any up elevator. Full throttle should make it climb and once it is at the altitude you want, you should be able to cut back to about half throttle and cruise and maintain altitude.
Sierra Gold
