RCU Forums - View Single Post - UCD 46 Vibration
Old 01-24-2004 | 09:49 PM
nitro wing
Default RE: UCD 46 Vibration
Did the stock mount need carving to fit the 100? does the crankcase easily clear the motormount beams? no tight fit?What prop did you use and did you carefully balance the prop? are you running a spinner? Exhaust is not touching firewall,and is secure? is engine evenly snug on mount?
