RCU Forums - View Single Post - Question on elevator servos?
Old 01-25-2004 | 10:56 AM
THE EDGE
Default Question on elevator servos?
Tom,
Just put my DA 50 (with 2 1/2" standoffs)on my Edge, and the 3/4" blocks of wood had to be cut down 1/8"to get my spinner backplate clearance down to a tolerable 1/8" in front of my cowl. I dont think that will be a significant difference,do you?
Anyway the question I have for you is I am planning to put a 24oz smoke system on this plane next to my fuel tank, do you know if it would be advisable to put the elevator servos in the fuse mid-section or not? Im not sure about the long pushrods strength or if this is just not at all recommended.
Also this is an excellent ARF I could not have even imagined how sturdy an ARF could be built and clean too.
I need to know what kind of paint is on the cowl, lacquer or urethane? (Mine is all white)
And finally, how far behind the front edge of the fuse is the landing gear supposed to be?
thank you again CK
