RCU Forums - View Single Post - Good knock-around plane suggestions
Old 05-30-2002 | 02:14 PM
f2racer
Default Good knock-around plane suggestions
Originally posted by basmntdweller
MHawker,
I've read reviews of the Magic but most weren't very favorable. What engine are you running on yours and how is the planes durability? I have an OS 32sx that would work on a lighter plane such as this one but it's on one of my other planes and I hate swapping stuff around. I'm leaning towards using a new, old K&B 40 I've had since the 80's for whatever plane I end up getting.
later,,,basmntdweller
I flew a buddy's Magic with an OS 32SX last Sunday and it was an absolute riot. The plane will literally loop within a length of itself, rolls are amazingly quick and the responsiveness of the huge rudder is amazing (can you say knife loop?). The 32 is a good setup, but he's getting another Magic and sticking a mid-sized 4 stroke (I think he's considering a Saito 56 or Enya 53) in it for some extra thrust. The plane hovers nicely with the 32 (at about 1/2-3/4 throttle), but just can't seem to pull out of it vertically, so I think the 4 stroke will help out quite a bit. It's definitely his favorite plane.
As for my hanger, I just finished building an Uproar (the kit equivalent of a GP Dazzler) to have as a beat around plane. It too is extremely light. Unlike the Magic, the Uproar and Dazzler has a much thicker, almost symmetrical airfoil which should aid in low speed aerobatics, but allow it to be flown with a little more authority. Unlike the Magic, the tail control surfaces are not quite as large, so it may not be the 3D trainer that I wanted to build (although I did end up enlarging the rudder some), but it should still be a good fun-fly type plane. The Dazzler does come with sticky backed covering (bad) and costs a bit more. I'd probably pick the Magic if I was limited to ARFs...
