RCU Forums - View Single Post - Rough Settings for Evolution .46
Old 01-25-2004 | 05:12 PM
F4U Killer
Default RE: Rough Settings for Evolution .46
You might also check the fuel line between the needle valve and the carb it might have got nicked if you did not remove it while installing the engine.
You might also review your fueling procedure. You might have injected something into your fuel tank which in-turn might have lodged somewhere in your fuel lines or intakes.
