RE: Useing Heat and Windex to apply monokote graphics
Hey Gator,
I tried this method a couple weeks ago on my Burrito. Most of the areas went great but just behind where the sheeting stops there was still noticable covering sag between ribs. My graphic was on both sides of one rib. I could get one side to lay down or the other but not both. I tried to carefully heat the wrinkling area to try to shrink it down so it would lay down but it really made it worse. What is the trick to correct this? I'm sure you've ran into this before after seeing many of your pieces of art.
Thanks,,,basmntdweller
