RE: WONDER advice.
Well, I gotta disagree with a 25 turning the Wonder into a dog. I have an OS FX.25 in mine and it is a rocketship! You had better be an experienced pilot if you want to try WOT with that combo!.
PS, set your prop so that it meets compression at the 3 o'clock position. That way, when you land, you can kill the throttle, and the wind will move the prop out of the way for you.
