RE: Need some help Bax!!!
Nitro in fuel will tend to dissolve the CA you used. If you get the assembly really clean and oil-free, J.B. Weld epoxy will do the job, as long as you don't block the fuel passage. Roughen-up the sides of the area with a bit of sandpaper first, so the glue will hold.
