RE: OS FS-91 Idle settings problem
Check the valve/rocker arm clearances. Then "ball park" the carb per the instructions. If you don't have them, email us at the address below to get a set emailed back.
If the carb's set correctly, and the valve lash is correct, then the compression seal is starting to go. When an engine starts wearing out, idle and acceleration are the first things to go south.
