RCU Forums - View Single Post - Hi torque servo?
Old 01-26-2004 | 06:59 PM
Lost Down Under
Default Hi torque servo?
I have 2 x 1/4 scale 14.5kg servos side by side on a Y lead opperating a leg on a large boat, in a push pull set up. The torque from the leg is over powering the servos.
My question is if I go to 1 servo in a hi torque range of about 28kg & using the single arm as a push pull, is there a chance of fixing the problem?
Speed of the servo is not an issue.
What servos are available for this application?
Second question is if I feed 6V into the reciever (Futaba PCM), is it a 6V output to the servo?
Thanks for your time
Paul.
