ORIGINAL: Johnnylightning
Same thing happened to me w/ my UCD60. I tried everything!! Swapped servos, crystals, extentions, switches, batt paks, locations of everything and even took my complete flight pak out and laid it out onto a piece of board, in the same configuration as it was within the plane, so that I could move the anntenae around. I even tried a different Rx from another plane and the problem continued. couldn't fly the plane for 2 months after completion
***Turned out that I somehow had fried both receivers. One, with a bad 4.8v pak and one with an unregulated 6.0v pak. If you're gonna' use 6v's, regulate the pak.
Hope this helps and good luck!
The receivers are not fried because if I hook them up in one of the other planes, everything works great.
