RCU Forums - View Single Post - Pull-Pull... How twangy?
Old 01-27-2004 | 12:02 PM
Live Wire's Avatar
Live Wire
Default RE: Pull-Pull... How twangy?
I have a 1/5 waco and all the controls are pull, pull. I ran the cables to control line bell cranks then then from bell crank to servo's. The wires should be adjusted where there is no slack in control surfaces, to tight will damage servo's. On the bell crank's there is no pressure on servo's and they opperate normal, do not use plastic horn they will distort from constant pressure on them.
