RE: Useing Heat and Windex to apply monokote graphics
Gator,
Most people with your ability like to keep it to themselves or sell it for a price. Thanks for freely sharing your ideas with us. On the flag thread you mentioned after applying the design with windex you let the covering sit overnight, then you seal the edges with a Q-tip and trim solvent. Do you just apply the solvent around the edges or do you peel it up and apply it under the lip? Also do you cut your graphics dry? Have you tried to remove the backing on the covering and apply it to glass with windex before you cut it? If you've tried this does it affect the covering sticking to the base covering when you apply it to the model? Thanks again and there's a reason your threads are so popular, you should look into putting your ideas in print.
