RE: Engine Problems
If you knocked the carb off the engine, I'd start there. Order a new carb to start with, chances are you've got air leaking in around the base, and that can foul things up pretty good. But if you're seeing bubbles in the fuel line leading to the carb, you have other problems too.
Dennis-
