ORIGINAL: Matrix
Just a thought. Have you built any Carbon Fibre into the plane that runs parallel to any of your servo leads. I've had a similar problem with an all moulded glider with carbon spars.
Ian.
Ian,
I have carbon fibre landing gear and the two carbon fibre spars supporting the horizontal stab. The spars in the stab run perpendicular to the plane that the servo leads run on, but they are behind the rudder and elevator servos and therefore not close to the servo leads. The landing gear is under the fuse and forward of the servo leads for the aileron servos. A portion of it runs perpendicular to the wing, but it is a good 3 or 4 inches below the wing and well insulated with plenty of wood in between. Do you think this could make a difference?
Thanks for the input.
