RCU Forums - View Single Post - Engine Problems
Old 01-27-2004 | 05:14 PM
FLYBOY's Avatar
FLYBOY
Default RE: Engine Problems
Make sure the carb is on tight, make sure the O ring is ok under it, change the plug, and check the lo end needle. Sounds to me you have the low end too lean if it runs fine at high speed and when you go to low, it works for a second then quits, it sounds like it is starving on the low end.
