RCU Forums - View Single Post - Weird H9 Funtana problem
Old 01-27-2004 | 06:49 PM
tommy157
Default RE: Weird H9 Funtana problem
My Funtana had the same problem..I found the problem was antenna location..I had run the antenna inside a tube inside the fuselage..the wire had doubled up inside the plastic tube and caused interference by way of the two servos mounted in the rear..relocated outside and the servos are steady now....
