RCU Forums - View Single Post - Curious, will this body fit a TC3 or HPI RS4?
Old 01-28-2004 | 03:56 AM
ko's Avatar
ko
Default RE: Curious, will this body fit a TC3 or HPI RS4?
i dont have a digital camera cable for my computer yet so i dont have pics...
overall i think its a "fair" body... i did have it hard top for a while with a 50mm hole in the windshield and a 30mm hole in the rear window and like all my bodies i cut along the rear bumper skirt and remove it for maximum air movement without having a scoop effect...
after i wrecked it pretty bad i just cut the top off to see how it would perform as convertable and its very unstable that way...
so if i may suggest if you are looking for a honda body i say you should get the civic si body... its far more stable than the s2k... its what i'm running on my evo right now and it has alot better clearance room for the engine... also look into the accord, yet another stable body from honda...
but as anyone will tell you on this board the most stable body is gonna be the stratus
hope this helps
