The TGT did go up but stayed within limits.
The AH-1F had the improved intakes that was designed to prevent something like that from happening if you fired to many 2.75in Rockets at one time. That probably helped prevent a major TGT spike. The ECU did blow hot air instead of the snow it usually does when it is on ( the Cobra had the best AC system, I miss it)
Later
