RE: HELP! Old K&B40 Broken Ring / Startup
There're two gaskets front and back (see attached picture/you might not see the front one as is attached to the crankshaft). They're not cracked and seem to be all right when I attached them to the engine. Also, while holding carb lever the carb barrel is not moving (up & down) but I thought if the O-rings are old maybe the air still can pass through.
