RE: HELP! Old K&B40 Broken Ring / Startup
How much break in time have you given the new ring? Is the engine too tight again to turn up to higher RPM or idle properly? When you install a new ring the engine needs to be broken in again to seat the new ring. Even Dykes rings need some break in.
