Hummmm ... in YOUR own words ... it does NOT water-proof , but is a water displacer ...
READ what AMSOIL says about it and how THEY describe it ! )
MPHD Heavy Duty Metal Protector
A heavy duty spray lubricant fortified with special rust and corrosion inhibitors. Penetrates and adheres to metal surfaces, leaving a long lasting protective coating. Apply MPHD to any metal surface that requires a heavy duty lubricant or is exposed to the damaging effects of salt, moisture or chemical corrosion. Works as an undercoat, leaving a wax-like film. Recommended for motorcycle chains. Won't "sling" off. Dry to the touch. Doesn't attract dust. It is ideal for hinges, wire ropes and springs, nuts and bolts, motorcycle or bicycle chains, and for undercoating car doors, wheel wells, rocker panels, seams and other metal surfaces exposed to water, dirt or road salt. Product Code: AMH
Prevents rust & corrosion, even in salt water
Displaces water
Stops squeaks
Lubricates metal surfaces
Leaves a dry, long-lasting, wax-like film
Sprays into hard-to-reach places
Lubricant does not attract dust
Does not sling off
Ideal for chains & other heavy-use items
Taken right from the website ...
Seems there is a BIG dollar difference between the two items . Descriptions of the items are ALMOST identical ...
Corrosion X description
Amsoil description
