RE: EXACTLY HOW IMPORTANT IS RIGHT THRUST?
you could add rudder, but different amounts are going to be required for different throttle positions. a plane that is off on the right thrust is a pig to fly. my ucando needed quite a bit more than stock, before it would always fall off to one side or another on vertical lines, no matter what you did with the trim.
